رقم العضوية : 102
الاقامة : Downtown - Cairo, Egypt
السيارة: Daewoo Lanos I 1999
السيارة[2]: Daewoo Lanos II 2001
دراجة بخارية: N/A
hi man
do you have any slotted and/or cross drilled rotors for Daewoo lanos and Nubira ??
models are from 1999 up to 2003 and the rotors are the same for all nubira models (it is different actually but the different is in parts other than the rotors)
as for the lanos i am interested in whats available for the 1.6 version as the 1.5 version got pathetic brakes to start with so i always upgrade to the 1.6 spec then take it from their
i can send you rotor dimensions if it will make your search easier
رقم العضوية : 15165
الاقامة : Jeddah, Saudi Arabia
Marwan KandeelOwner & GM.Auto Works CorpJeddah, Saudi Arabia
رقم العضوية : 2960
الاقامة : Nasr city
السيارة: Skoda Roomster
السيارة[2]: Subaru Impreza 07
متأسف مكنتش شايف الموضوع هنا عشان كده كنت متابع هناك
M0uSS0It'S WhAt Makes A SUBARU ,A SUBARU
رقم العضوية : 15165
رقم العضوية : 15165
رقم العضوية : 102
دراجة بخارية: N/A
رقم العضوية : 15165
رقم العضوية : 102
دراجة بخارية: N/A
thanks bro
i got the rotors spec. through the brembo online catalog so if the P/Ns are wrong i will sue brembo
actually i have compared the mentioned measurements for both rotors to the ones i have and they are a perfect match... but as you can see those P/Ns are for OEM replacements and i need high performance rotors (slotted and/or cross drilled) that matches those measurements
as for fitment... the nubira rotors are the same as the OEM ones so if the measurements match then it will fit perfictly
the lanos ones are not the same as the OEM ones we got here... they are for the 1.6 version that we don't have here but i have managed to upgrade the braking system on the 1.5 lanos to match the one on the 1.6 version as you can see in this post
http://www.nilemotors.net/Nile/showthread.php?t=15264
BTW the 1.6 lanos rotors are the same measurements as the ones on the Vectra A with the 1.6 & 2.0 engines.
رقم العضوية : 15165
رقم العضوية : 15165
عزيزي، انا ممكن انصحك بالبكرات كبداية.البكرات دي عبارة عن طقم من 3 بكرات المونيوم مغلفة بكربون.الهدف منها تخفيف الحمل على الموتور.
-مجموعة البكرات تشمل: بكرة الكرنك،بكرة الباور ستيرنج،بكرة الدينمو.
-اجمالي الوزن اللي سيتم توفيره على الكرنك هو:4.5 كيلو.تخيل بقى ان المنطقة اللي انت بتخفف منها الوزن هي محور دوران الموتور و مصدر القوة في العربية،يعني كانك خففت من وزنها الاجمالي كتير جداً.
-عدد الاحصنة المتوقع الحصول عليه من تركيب البكرات دي 15-20 حصان.
غير كدا لو انت عايز اكزوست و فلتر هواء حنحتاج شوية وقت و تفاصيل اكتر عن العربية و ممكن نبدا بالصور اولا.
على فكرة سعر مجموعة البكرات دي لاعضاء المنتدى 2100 جنيه شامل جميع التكاليف واصلة لحد باب البيت.
التعديل الأخير تم بواسطة AutoWorks ; 05-08-2008 الساعة 04:28 PM سبب آخر: اضافة السعر
