النتائج 1 إلى 5 من 5
    الصورة الرمزية magdyelshikh
    رقم العضوية : 67710
    الاقامة : الاسكندرية
    السيارة: lancer1600
    السيارة[2]: opel vectra B 1.6 CD 98
    الحالة : magdyelshikh غير متواجد حالياً
    افتراضي طريقة برمجة ريموت المفتاح - Facebook Twitter whatsapp انشر الموضوع فى :
    1. Locate the Data Port under drivers side dashboard usually located to the right of steering column.
    2. Insert keys in ignition and leave in the OFF position.
    3. Make sure there are metal contact pins in terminals 1 and 4 and connect the Data Port terminals 1 and 4 with asuitable jumper wire, leave the jumper wire connected throughout the programming procedure. Make sure you
    know which terminals are 1 and 4.
    4. Within 10 seconds after connecting the jumper wire, press the Hazard Switch 6 times. Note: The doors will
    automatically lock and unlock once at this time indicating that the system is in the programming mode.
    5. Press the LOCK button on the remote to be registered three times within 10 seconds. Upon successful
    programming, the door will lock and unlock once.
    6. Repeat step 5 with up to 4 remotes (including any existing remotes) within one minute. After completing each
    programming, the doors will lock and unlock once.
    7. Disconnect the programming wire and remove the keys from the ignition.know which terminals are 1 and 4.
    4. Within 10 seconds after connecting the jumper wire, press the Hazard Switch 6 times. Note: The doors willautomatically lock and unlock once at this time indicating that the system is in the programming mode.
    5. Press the LOCK button on the remote to be registered three times within 10 seconds. Upon successfulprogramming, the door will lock and unlock once.
    6. Repeat step 5 with up to 4 remotes (including any existing remotes) within one minute. After completing eachprogramming, the doors will lock and unlock once.
    لا الله الاانت سبحانك انى كنت من الظالمين
    مجدى الشيخ
    الصورة الرمزية muhmado_furp
    رقم العضوية : 20937
    الاقامة : giza
    السيارة: لاتوجد
    السيارة[2]: Elntra 2009
    دراجة بخارية: لا توجد
    الحالة : muhmado_furp غير متواجد حالياً
    حضرتك ناقلها الطريقة دي استاذ مجدي ولا عن تجربه
    وياريت لو حضرتك جربتها تشرحلنها بشكل مبسط
    [S][all1=#ff0000]الحذر لايمنع القدر
    فارضي بقدر الله تكن أسعد الناس
    [/all1][/S]
    رقم العضوية : 67710
    السيارة: lancer1600
    اقتباس المشاركة الأصلية كتبت بواسطة muhmado_furp مشاهدة المشاركة
    ايون انا نقلتها ولكن مجربها قبل كده فى برمجة الاوبل فكترا
    المفيد انك بتضع المفتاح فى الكناتكت وتفتح الكنتاكت وتتركة حوالى 10 ثوانى من غير ما تدور السيارة وبعدين بتدوس على زرار غلق السيارة الموجود فى الريموت لمده 6، 7 ثوانى سوف تلاحظ ان السنتر قام بالغلق لوحدة بعد الضغط السابق على الزرار الغلق قم بالضغط على الزرار الخاص بالفتح بنفس المدة سوف تلاحظ قام بالفتح للسنتر ثم قوم بدوراة الموتور واتركها دايرة لمدة دقيقتين او ثلاث ثم بطل الموتور .. اخرج من السيارة وجرب الريموت ان شاء الله يكون شغال تمام
    مجدى الشيخ
    رقم العضوية : 20937
    الاقامة : giza
    السيارة: لاتوجد
    اقتباس المشاركة الأصلية كتبت بواسطة magdyelshikh مشاهدة المشاركة
    شكرا يا استاذ مجدي متحرمش من معاليك
    بس معلش استمحلني
    هي الطريقة دي تنفع في حالات ايه بالظبط
    يعني مثلا عامل مفتاح عادي مش مشفر واقوم عامل الطريقة دي يشتغل
    ولا ايه معلش مش فاهم
    اصل حضرتك بتشرح ان الواحد يدوس الريموت والمفتاح في الكونتاكت فانا معلش مش فاهم
    [/all1][/S]
    رقم العضوية : 67710
    السيارة: lancer1600
    بس معلش استمحلني
    استاذى الكريم الطريقة تنفع مع المفتاح الاصلى اللى هو مرسوم عليه علامة الانسر وفيه زرارين واحد لغلق السنتر والثانى لفتح السنتر والمفتاح ده اساسآ بيكون بداخلة فحمة صغيرة سوداء وهى شفرة العربية ووحدة الريموت التى ترسل اشارة الى قطعة مثبتة داخل السيارة تحت طارة الريكسيون تسمى بالأمبوليزر تقوم بأستقبال الاشارة من الريموت وفيها الشفرة الخاصة بسيارتك فعند وضعك المفتاح داخل الكونتكت يتم التعرف
    على الشفرة الموجودة فى المفتاح والموجدة فى الامبليزر وعند حدوث ذلك يمكن تدوير العربية لانه من الممكن ايجاد مفتاح يدخل قى طبلة الكونتكت وكمان يفتح معاك الموسوجر بتاع الدريكسيون ولكن مايدورش العربية بسبب الفحمة الغير موجودة او بسبب اختلاف الشفرة .... وعلى ذلك لما بتعمل مفتاح للعربية عند بتاع مفاتيح لازم يكون فية نفس شفرة المفتاح الاصلى علشان يدور العربية ولكن المفتاح ده لا يستطيع قتح وغلق السنتر الا اذا عملته فى التوكيل وده بيكون بمبلغ باهظ ......
    وطريقة برمجة المفتاح اللى سبق شرحها بنحتجها عندما يفقد المفتاح الاصلى البرمجة بتعته ...
    واى استفسار تانى انا تحت امر معاليك
    مجدى الشيخ
  1. طريقة برمجة ريموت التويوتا كل الموديلات 2003>2008
    بواسطة araby1980 في المنتدى تـويوتـــا
    آخر مشاركة: 02-03-2014, 03:38 PM
  2. استفسارعن برمجة المفتاح لانذار وولف
    بواسطة mat7oon في المنتدى كــماليــات السيـــارات و الإكسسوارات
    مشاركات: 13
    آخر مشاركة: 06-08-2013, 02:24 AM
  3. اريد طريقة برمجة ريموت الأسبرانزا 620
    بواسطة waeltealeb في المنتدى مشاكل الكهربــاء
    آخر مشاركة: 29-01-2012, 11:08 PM
  4. طريقة برمجة ريموت ال-gen2
    بواسطة mg3ain في المنتدى بــروتـــون
    مشاركات: 1
    آخر مشاركة: 11-01-2009, 09:59 PM
  5. برمجة ريموت جديد
    بواسطة ehabspc في المنتدى كــماليــات السيـــارات و الإكسسوارات
    آخر مشاركة: 25-11-2008, 06:45 PM
